Power Cables Type RLB2 - how to find technical data?
August20
Power Cables Type RLB2 are used to connect MS2N servo motors with ctrlX DRIVE servo drives.
How to find technical data for the type RLB2? In Cable booklet Version 7 this type is currently not included.
Drives_Uwe
Please use the ctrlX Configurator (https://www.boschrexroth.com/ctrlx-configurator/) to get the correct cables.
macmotor
The cable's technical data cannot be indicated for every individual cable type in a static manual, that would be almost impossible to visualize.
Instead see chap. 11 of the "cable booklet edition 07" (mat.no. R911401939/R911401938), which contains the technical data of the bulk cables used.
  • Note the respective cable type reference from the type code , e.g. RLB2-011CBB-NN-xxx,x
  • Check table in chap. 9.1. for reference of type code and bulk cable type, e.g. code C = REL0105
  • Take bulk cable technical data from chap. 11
macmotor
Update:
All information on our cables and connectors for ctrlX DRIVE and related motors are available on our public online documentation platform:https://docs.automation.boschrexroth.com/iirds/cdp-metadata.boschrexroth.de~iiDC~Product-Kabel-und-S...
incl. "reference manual" current edition 04, data sheets etc... in DE and EN, everything downloadable as PDF
