Labview/Matlab with ctrlx Drive
Yacine
is the OpenCoreInterface toolkit updated to work with ctrlx Drive ? the goal is to control ctrlx Drive through Labview/Matlab .
Thanks.
5 REPLIES 5
RexCode
Hello Yacine,
yes the EAL library works as well with ctrlX DRIVE if you use the latest version (> EAL 2.3.0)
So you can control (positon, velocity or torque) your drive by a PC application like in the past.
Christoph
Yacine
Hello Christoph,
Thanks for the answer,
do you have the link to download version >2.3.0 , on Bosch Rexroth wesbite, only 2.2 is available.
Thanks.
Hello Christoph,
how to establish the connection with ctrlx drive to labview? Via the small screen and usb connection?
Thanks, Adam
Drives_Uwe
Via Multi Ethernet connection.
