11-02-2022 03:11 PM
Hello colleagues,
we have ot connect an ENDAT2.2 ENCODER with a battery box .THe encoder is part of an Harmonic frive with MZE encoder interface.
0v of the battery box has to be connected to the drive. do you see any tricky point witch coulb be an issue?
thanks for your support
11-03-2022 09:13 AM
Please note the information in the description concerning EnDat 2.2 encoder with battery. The battery voltage is currently not monitored. If the battery voltage is not present at the encoder, there can be problems with the position.
https://docs.automation.boschrexroth.com/doc/1569882602/digital-encoders/latest/en/
