04-10-2024 01:34 PM
I have a problem with the parameter S-0-0145. I use this parameter to set the output pin 8 from the drive. The problem is that the parameter keeps getting overwritten by something to 0. In my PLC program where I set the parameter it says it's true but when I check the drive parameter in the drive engineering then I see it switching between 0 and 1. So right now I have a pulse signal that is coming out of my drive. Has anyone encountered this problem before?
04-10-2024 04:04 PM
Hello @JLG_War,
you mean you write from your PLC via a bus on the S-145. And the S-145 you use on the local IO of the ctrlX DRIVE ? ctrlX DRIVE (or IndraDrive ?, which Firmware ? ) .
04-11-2024 10:59 AM
Perhaps best provide the parameter file of this axis in format "all parameters".
04-11-2024 04:14 PM
I've fixed the problem. The problem was the ethercat master, for whatever reason it would write my data back to 0. I solved this by deleting the old ethercat master and adding a new ethercat master.
