02-03-2023 11:45 AM
Hello CtrlX Team
I have a question,In my project I encouter ctrlx drive error F7020 When machine running.
I have checked P-0-3270.0.2 and there is no problem.
I also checked velocity command value it's also ok.
So I feel confused,does anybody know how to solved this error? Thanks.
02-06-2023 08:52 AM
Please send the drive parameter file in format "all parameter" in order that we can check the diagnosis logbook.
If possible try to take a scope reading when the error occurs, use the signals S-0-0040, P-0-3238 and P-0-3258.
02-07-2023 02:41 AM
Hello
At current I can't take a scope and can't save ctrlxdrive parameter when the error appeared .
please see the link:Re: CtrlXDrive Connection was interrupted issues? (boschrexroth.com)
Thanks your advice,I will have a try.
