07-28-2022 09:22 AM
I'm experiencing problems with getting online on the ctrl-x drive. It's a XMS2-W0006ANN-01NETT0 drive and the ctrl-x firmware I use is ctrlX DRIVE Engineering 01V16.2
When going online via the USB-C panel input or the XXF21-22 connection port I'm experiencing the same problems, it's continuously connecting and losing his connection as visible in the attached video.
Has anybody faced the same problems and is there a solution for it?
07-28-2022 06:12 PM
That looks very strange. Please check your connection cable or your settings for the EtherNet adapter you are using.
We never experienced such a behavior.
08-01-2022 07:57 AM
Please create an error report with "Help -> Create Error Report..."
11-07-2022 10:19 AM
Hello @WEMO_MPA
I have a customer experiencing a similar issue. Did you get any resolution to this problem?
Many thanks
11-22-2022 03:29 PM
Any news to this topic?
11-22-2022 03:36 PM
Hello @DCEN_Tony ,
unfortunately not yet.
We did park the Ctrl-X drive transition for the moment, I think we will continue with it in a few months.
Kind regards,
Mike
11-23-2022 08:55 AM
Whenever the issue pops up again, please create a system error report as already told and post it either in here or get in touch with your regional application or service support.
