09-06-2023 10:20 AM
Is it possible that ctrlX Core (any version) could be an EtherCAT Master (for Frequency Converters and Pumps) and an EtherCAT Slave for some other Master Controller at one time?
Best regards, Filip
09-06-2023 10:52 AM
Hi Filip_K,
this is not yet possible, ctrlX CORE can only be a EtherCAT Master at the moment.
Maybe you have other options to solve your task, like OPCUA, or Profinet Device?
09-06-2023 12:16 PM
05-03-2024 10:01 AM
Hello
i have the same demand from customer who has B&R PLC : he wants us to be ethercat slave.
is it still not possible ?
regards
05-03-2024 10:05 AM - edited 05-03-2024 10:06 AM
The ctrlX OS EtherCat master in a ctrlX CORE still cannot be EtherCat slave.
You could use an EtherCat master to master gateway or try using a soft EtherCat master e.g. PLC based. But both is not available as Rexroth product.
I would also recommend to use another ethernet based bus protocol like OPC UA.
05-13-2024 09:06 AM
Hello ;
thanks.
