03-04-2022 12:08 PM
What requirements, e.g. apps are needed to communication with a Siemens PLC over Profinet?
BR
03-04-2022 02:00 PM
At the moment we are still working on adding a PROFINET controller and device to our ctrlX COREplus. So we do not have a hardware or app for using it.
At the moment you can use a PLC based soft stack of CODESYS. See the storage area for further information.
03-04-2022 02:07 PM
Thanks, maybe a dumb question.
But do I understand it correctly, that using CodeSys on ctrlX it is possible to connect a Siemens PLC with a ctrlX Core device?
From a hardware point of view, the cable will still be connecting the Siemens PLC though our multiEthercat on the ctrlX Core ?
03-04-2022 02:19 PM
The PLC soft stack would run in the ctrlX PLC app and would use one of the standard Ethernet ports (XF51, XF10) for the communication not the EtherCat port (XF50). Which one will be declared by the IP set in the code in the PLC.
For control interfaces see our online documentation:
"ctrlX CORE Controls, Operating Manual --> Interfaces --> Interface description"
06-07-2022 12:41 PM
What is this licence that the soft stack profinet master is requiring? I can't find any place to enter any licence and in the package manager it says no licence required.
06-07-2022 08:09 PM
It's a CODESYS license. Please take a look at the CODESYS homepage.
To install this codesys license please take a look at the latest post of this issue. https://developer.community.boschrexroth.com/t5/ctrlX-WORKS/Version-Control-SVN-or-GIT/m-p/21397#M24...
06-09-2022 12:06 PM
What is this licence then, which has our R-code?
06-09-2022 12:45 PM
You are right. We have now this license / Add-On in your ctrlX STORE too. (Sorry for confusing...)
To get the Add-On package you can download it by pressing the "Get in now" Button
To get the license you have to order by BoschRexroth by using this number.
Additional there is a manual how to install the package/license at the end of the Store page .
