06-21-2024 06:20 PM
I can enable the drive but gets stuck on StandStill Pending. I checked Status word and looks fine. Another thing that i noticed is the Actual Position only updates once and then stays same value. I checked this with Elmo software being online.
any suggestion on what the issue could be?
06-27-2024 01:04 PM
Hi Usalas,
did you see and follow this guide?
Connect ctrlX CORE with ELMO Drive (boschrexroth.com)
Many regards
a month ago
I encountered the same problem while using the ctrlx drive!I used the XCD drive,One of the axes can be enabled, but an other axis display 'standstill pending' when I enabled!
