In which way is the performance of the ctrlX CORE motion influenced by adding APP's like VPN, Firewall and Iot Gateway?
Is there an easy way for the customer/user available to determine the load of the ctrlX hardware?
Performance:
If the RM 20.11 is used there is no influence to the performance. Because the different APPS are using diffenent CPU Cores.
Easy way to check the CPU load:
