Performance Comparisons for ctrlX CORE?
Trumpf_Gunnar
In which way is the performance of the ctrlX CORE motion influenced by adding APP's like VPN, Firewall and Iot Gateway?
Is there an easy way for the customer/user available to determine the load of the ctrlX hardware?
Jochen_Mueller
Performance:
If the RM 20.11 is used there is no influence to the performance. Because the different APPS are using diffenent CPU Cores.
  • Core 0/1:  generall use (e.g. VPN, OPC-UA, ...)
  • Core 2: PLC
  • Core 3: EtherCat, Motion, Datalayer
Easy way to check the CPU load:
  • Actual there are only basic information
  • With next release it's planned to have a graphical overview over all running task.
CodeWasi
Hello Gunnar,
find 'general' CPU Info in meantime under:
