a month ago
Following the guidance provided here:
https://github.com/boschrexroth/node-red-contrib-ctrlx-automation/blob/master/doc/REFERENCE.md
I setup a dedicated nodered user with limited permissions, but now I can't browse through the datalayer to find the data that I'm looking for.
I've given it these permissions: (and a bunch of others)
What else do I need to give it so that it can access and edit the datalayer?
Thanks!
a month ago
Hi @LucasTBC ,
When you say you can't browse the datalayer, do you mean in the ctrlX Web UI, or via Node-RED?
I replicated your user permissions and am able to browse the datalayer from the ctrlX Web UI and Node-RED. I am using ctrlX OS version 2.2.4
a month ago
I was talking about browsing through the Node-red UI, but apparently I just needed a reboot or something. Because now it's working.
Thanks!
