06-16-2022 12:42 PM
For supporting MODBUS-TCP, the suggestion was to use the PLC App with CODESYS - Fieldbus communication Add-on, but I did not find one item for Modbus support in the configuration tool.
Is any documentation available to describe this functionality?
06-20-2022 11:24 AM
Hi GBARyder,
maybe this was a missunderstanding.
Modbus-TCP is not a Codesys Addon, you can use directly in PLC Engineering our library CXA_ModbusTCP.
11-03-2022 10:55 AM - edited 11-03-2022 10:56 AM
Dear All,
Customer want to use our CtrlX Core (Modbus TCp IP protocol) connect to BACnet IP via Intesis gateway as link:
Do anyone have experience about this gateway.
Do we need any recheck, @TheCodeCaptain, @CodeShepherd please help
And they ask:
As I check here, there is no limit information:
https://docs.automation.boschrexroth.com/doc/1616011786/il-modbustcpclient/latest/en/
Thank you so much
11-09-2022 08:46 AM
I don't know the answers to the questions asked, but I also have an alternative solution. Our XM2 and XM4 controllers support BACnet IP as client and server. A connection between the ctrtlX core and the XM controllers would then also be possible via OPC UA. This could be more powerful than a Modbus/TCP connection.
