How to read motion operation mode node status ?
Max1
Hello rexroth team
I have a question,I want to know how to use "fb DL_ReadNode" to read motion operation mode status?
and  also I want to know how to use "fb DL_WriteNode" to forced motion operation mode to running?
First I like to mention that in the CXA_MOTIONINTERFACE there is an easy to use function included:
//Reading mode
ImcStatus.Admin._OpModeAck;
//Setting mode
ImcCtrl.Admin._OpMode := MB_IMC_MODE_CONTROL.IMC_MODE_CTRL_RUN;
ImcCtrl.Admin._OpMode := MB_IMC_MODE_CONTROL.IMC_MODE_CTRL_CONF;
For your question, as all information can be found in the Data Layer you can read as follows:
Declaration:
PROGRAM MotionStatus
VAR
	fbDL_ReadNode: DL_ReadNode;
	bReadExecute: BOOL;
	bReadDone: BOOL;
	bReadActive: BOOL;
	bReadError: BOOL;
	ReadErrorID: CXA_Datalayer.ERROR_CODE;
	ReadErrorIdent: CXA_Datalayer.ERROR_STRUCT;
	ReadValue: STRING;
	diSize: DINT;
END_VAR
Implementation:
fbDL_ReadNode(
	Execute:= bReadExecute,
	Done=> bReadDone,
	Active=> bReadActive,
	Error=> bReadError,
	ErrorID=> ReadErrorID,
	ErrorIdent=> ReadErrorIdent,
	ClientId:= ,
	NodeName:= 'motion/state/opstate', //Path to the node at the Data Layer
	Value:= ReadValue,
	Size=> diSize);
Writing with DL_CreateNode because it is a command:
Declaration:
PROGRAM MotionState
VAR
	fbDL_WriteNode: DL_WriteNode;
	bWriteExecute: BOOL;
	bWriteDone: BOOL;
	bWriteActive: BOOL;
	bWriteError: BOOL;
	WriteErrorID: CXA_Datalayer.ERROR_CODE;
	WriteErrorIdent: CXA_Datalayer.ERROR_STRUCT;
	WriteValue: STRING := 'Configuration'; //Use 'Booting' to get to 'Running'
	fbDL_CreateNode: DL_CreateNode;
	WriteReturnValue: UDINT;
END_VAR
Implementation:
fbDL_CreateNode(
	Execute:= bWriteExecute,
	Done=> bWriteDone,
	Active=> bWriteActive,
	Error=> bWriteError,
	ErrorID=> WriteErrorID,
	ErrorIdent=> WriteErrorIdent,
	ClientId:= ,
	NodeName:= 'motion/cmd/opstate',//Path to the node at the Data Layer
	ValueIn:= WriteValue,
	ValueOut:= WriteReturnValue);
