my customer has an issue regarding the configuration of a machine. He wants to upload a configuration file (can be *.csv or *.xml) and want to access this file in different applications.
What is the preferred way, to upload such a single configuration file to the ctrlX?
If I upload the file, how can I access this file from other apps? For example, if I upload the file via FTP, I have not the necessary security rights, to access this files in an app.
I found only the way using the Configurations mechanism, to upload files to the ctrlX. But in my opinions it is not very intuitive and I have no idea, where I can find the uploaded files and how to access this via other apps.
Can you please give me an idea, how to solve this issue?
The app data (aka configurations) folder is the easiest way for uploading data and sharing them with different apps. Therefore you can use following ways:
To get to this data from other apps you can use the following path. See e.g. this topic.
/var/snap/rexroth-solutions/common/solutions/activeConfiguration/
it would be nice, if I can upload the files directly in the active configurations. Now I have to use a 3rd party software, to solve this issue or otherwise i have to go the complicated way (downloading configurations, editing archive and add my config-file, uploading archive).
But for now, it works for my customer.
Thanks for your fast help.
So you/your customer would like to upload this file via the web page of the ctrX CORE directly without using any further tool? E.g. via drag&drop or upload button to the app data?
yes correct.
if you have the correct / necessary user rights, you can upload a file in your configuration. This file is accessable via other apps and you can use these files in your applications.
This actually not included but we will take it as a feature for further versions. Thanks for bringing this up.
