Core not appearing in CtrlX Works after system updates
James
After updating the motion, PLC and EtherCat Master apps to v1.12, the Core still appeared in CtrlX works when refreashing for devices. However after updating the system apps, and the the kernel I am no longer able to see the core in CtrlX works. When pinging its ip address via the command line I can still establish communications however. Is there a way to restore the Core?
Thanks,
James
Jochen_Mueller
Hello James
what means updating Motion, PLC, EterhCat Master apps to V1.12 without System Apps? The update to the V1.12 (from versions below) have to be done by image update with a SD-card - please see ctrlX CORE Runtime Release Notes_EN.pdf. So I don't understand this.
Regarding the issue that you don't see the device at ctrlX WORKS you can check the IPv6 configuration. Because via this path ctrlX WORKS check the possible availalbe devices.
Jochen
