08-02-2021 12:09 PM
In your advertisement video you mention a SQL database, that can be used for acquiring data with ctrlX for IoT applications. Is it successfully tested on a ctrlX CORE, or is a feature limited to WebIQ server running on a Windows OS on IPC?
08-26-2021 01:52 PM
Hello, thanks for the interesting question.
We have integrated an SQLite database in our WebIQ server and we use it, among other things, for storing historical process data (trend data recorder) and historical alarms. This also works very well on a CtrlX core, but there are limitations with regard to storage capacity and write speed.
Direct access to the SQLite database is not provided.
Hope that answers the question
webiq-eg
09-10-2021 06:12 PM
