dynamic precision on displayed value
Borje
Hello all,
I try to design a Web HMI with the WebIQ HMI Designer. I want to have the precision (number of digits) on dsiplayed value according to a process variable. Is that possible?
We have different machines with different speed ranges. Sometimes we want to show 1 digit and sometimes 2 digits on speed value. We have a tag (INT) that tells number of digits.
Greetings
Börje
webiq-eg
Re: dynamic precision on displayed value
Hello, thanks for the question.
The decimal places can be set in two ways:
1.) Directly in the configuration of the widgets (e.g. iq-input-field or iq-text-display):
2.) When configuring the process variables in the Process Data Manager. If this variable is then used in a widget, this setting is used as the default:
Hope that answers your question.
Many greetings
webiq-eg
Borje
Hello
Yes, but I want it dynamic. Can you somehow have it dynamic and dependign on a tag vealue?
We have a tag that is 0 when we want 0 decimal places, 1 when we want 1 decimal places and so on.
webiq-eg
you can do it with a little Script, which you can embed into a 'LocalScrip' Widget. I enclosed an example app which demonstrates it and you can try it out.
     * Implements local-script run function.
     * This function will be called each time a local-script will be enabled.
     * @param {LocalScript} self instance reference of local-script control
    module.run = function (self) {
        const im = shmi.requires("visuals.session.ItemManager");
        let tok = null,
            ctrl=null;
        ctrl = shmi.ctrl(".iq-text-display"); // get the reference to the Widget to apply the dynamic digit position
        if (ctrl) {
            // e.g. 'SInt' is the process data value to switch the digits
            // Subscribe 'SInt', this means the callback function will be called each time, the process value changes
            tok = im.subscribe(["SInt"], (name, value, type) => {
                if (value) {
                    ctrl.config.precision = 4;
                } else {
                    ctrl.config.precision = 3;
                ctrl.disable(); // reinitialize the Widget
                ctrl.enable();
        } else {
            shmi.notify("Widget not found");
        //Place your Code here
        /* called when this local-script is disabled */
        self.onDisable = function () {
            tok.unlisten(); // free the resources of the subscription
            self.run = false; /* from original .onDisable function of LocalScript control */
Hope that helps.
Regards webiq-eg
