WebIQ: Trend, I can't see data
LunatiX
I've got a trend object but I can not see the signal from a OPC UA source, t.e. cpu-utilisation-percent:
Other signals are working well, t.e. DSaw.
The value of cpu-utilisation-percent is reading well, but will not be displayed in the trend object. The date and time of the CORE is set correctly.
As an attachment you will find a easy WebIQ project.
Used System, App-Data
  • RM21.11.2
  • WebIQ Server version 2.10
5 REPLIES 5
webiq-sk
Hello LunatiX,
for a variable to be shown in a Trend Display the limits have to be set:
Regards,
Sascha Kimmel
giustola69
I still have the problem: using the WebIQ lolachost server the trend function works but if I use the server inside CtrlX ( the app ) it doesn't work using the same variable "SinVar" which is an internal var. But also using a var coming from the PLC it doesn't work either.
Please let me know what I'm doing wrong and hoe I could make the trend run connected to the CtrlX.
Many thanks
Giuseppe
webiq-sk
Did you set the min/max values for the SinVar imported from ctrlX correctly?
Tasty_Tech
I tried this but still not working could someone please support?
webiq-sk
@Tasty_Tech Can you please create a new topic for that? This one's been solved. Also, please provide the HMI so we can analyze it. Also, this post refers to the legacy Trend widget - I assume you are using the current Trend widget? Once again, can you please create a new topic for your issue?
