08-18-2022 12:02 PM
I would like to display "seconds" tick on the x-axis of the standard trending display object.
Is this possible to achieve this via the standard settings?
CL
08-19-2022 02:34 PM
If you have the app not loaded or running you can open the file json/layouts/app-model.json.
There you will find the "time-format" setting for your trend display which you can change:
If you only use "$ss" there only the seconds would be shown etc.
Please be careful when editing this file and be sure to make a backup before making any changes as if this file contains invalid JSON the app will not work anymore.
