Place a WebIQ workspace on a server.
Salmi_Manal
Is it possible to place a WebIQ Workspace on a server in order to be several to modify the same project or can we cooperate in the same project using GitHub?
Thanks in advance,
1 REPLY 1
HmiGuide
Using a ctrlX CORE as WebIQ server, allows you to modify the same project from different PC's and users. The PC must be in the same network as the ctrlX. Keep in mind that there is no versions handling, therefore you have to take care of the following things:
  • Only one user can edit the project at the same time
  • When a second user tries to edit the project, while it is edited by anyone else, he gets a notification.
    • There is no hint, which user is editing the project
    • Therefore you should publish the project, right after you finished your changes
  • Create backups from your project, with the WebIQ Export functionality
