Open a Pop-Up Menu activating an external variable?
ericvergara
Is it posible to open a "PopUp-Menu" Overlay activating an external variable of the PLC?
We want to open this menu directly via a rising edge of the PLC, no need of screen buttons,
Thanks in advance,
webiq-sk
To open a popup menu you can simply write a LocalScript that subscribes to the item and opens the popup window - add the attached code to a new LocalScript replacing the original module.run method. Then, rename your popup to "my-popup" (or change the name in the config part of the script) and configure everything else in the script in the config part.
A quick note: as your HMI can be opened on many different browsers at the same time this has to be taken into account - depending on your implementation you probably want to close the popup on all browsers once something has been done on one of them maybe to avoid confusion.
ericvergara
We have tried with the script and it worked!
Thank you for your help!
