Is there a provision to generate a report document (ex: .csv or .pdf) using data from the process tags?
Thanks
Hi Tamer,
Basically yes, but this must be done via a script, e.g. a customer-specific UI action in JavaScript. In csv it's pretty easy (I'll create a simple example and attach it to this post next week). PDF is also possible, we have already implemented something like this here, but an open source framework must be used here. If you need specific support for a customer project there, please contact us.
Many greetings
webiq eg
Thank you, an example would be great.
Any updates about the sample .CSV report file generation please? We are currently working on a project that requires this functionality.
Thank you.
Thank you so much, this was very helpful.
Is there any documention available for the data structure accessible through the JSON code (ex: ItemManager.readDirect)? I would like to build more functions through the code tool.
Thanks
you can find the JavaScript reference for programming here: https://www.smart-hmi.de/user/download/deliver/docs/documentation-webiq-visuals-reference-2.11-9600/...
the websocket api for accessing the server here:
https://www.smart-hmi.de/user/download/deliver/docs/documentation-dev-connect-apidoc-version-2.11.x-...
Many helpful "How-tos" in the Documentation area of our Website (after registration):
https://www.smart-hmi.de/user/docs
Best regards
webiq-eg
