12-20-2021 02:52 PM
Is there a recommended way to prevent simultaneous use of a screen with WebIQ. I am considering a scenario in which 2+ users may have access to a screen required for jogging an axis. What is there to prevent another user from accidentally jogging an axis and creating a potetnailly dangerous situation?
02-14-2022 08:38 AM
this is per se not a WebIQ issue but a logical issue where you have to find a logical solution regarding locking as in a multi-user system parallel uses are possible. You also need to take into consideration that when someone has exclusive access he might be able to lock the system indefinetly if you do not have an automatic unlocking implemented after a certain time with no action has been implemented.
Regards,
Sascha Kimmel
09-12-2022 05:07 PM - edited 09-12-2022 05:07 PM
The parallel access of screens is a important issue, but right now there are no templates or functions to support our customer to implement it. I keep this issue in mind, hoping that we can provide some ideas how it can be implemented in the future.
But right now there is nothing what we can provide, neither from BoschRexroth nor from SmartHMI.
