10-17-2024 03:19 PM
I tried to run a Pytorch ML model on the virtual core. Therefore I followed the instructions described in this community example https://developer.community.boschrexroth.com/t5/Store-and-How-to/How-to-run-Machine-Learning-Models-...
The model runs perfectly fine in Debug mode but when I build the snap and install it on the virtual core it does not work anymore. Does somebondy have an idea what might be the problem here?
Thanks in advance 🙂
10-17-2024 05:23 PM
Are there any related messages in the diagnostic log? This will be difficult to diagnose without more information.
You can also view the snap logs via the QEMU terminal.
Username: rexroot
Password: rexroot
sudo snap logs SNAP_NAME
An alternative would be to execute the application with remote debugging.
10-23-2024 12:31 PM
Hell,
I contact you in PM. We are planning some solutions which can be officially used 😁
