11-27-2023 09:50 AM
Anybody has expererience in integrating a Wittenstein Cynapse gear in the ctrlX world?
Expecially which realtime and historic data is available in the datalayer is for me interessting?
Does there exist a manual or how-to to describe how to use this for predictive maintenance?
Best regards
11-27-2023 10:14 AM
Please have a look to the related links area in the ctrlX SOTRE in this community for further information.
11-27-2023 10:33 AM
Yes, but I don' think they answer my questions.
11-27-2023 02:54 PM
So, did you already have a look the links?
Like e.g. to their information page with the operating manual for cynapse e.g. chapter "7.2 Process data" describing data available from a gearbox.
You could order a whitepaper and things more.
I will forward your questions to their support and see what information are given back.
For general information how to connect e.g. IO-Link gateways see our how to collection.
12-12-2023 09:59 AM
Hello Servodude,
are your questions regarding our products still active?
For the connection of a WITTENSTEIN cynapse® sensor into the ctrlX world you need to connect the IO-Link-Master to your ctrlX device. You have the options to do this via fieldbus connection or an IoT-Port of your Master with the use of protocols like e.g. MQTT.
More information regarding cynapse® and the Smart Services is also available on our website: cynapse - WITTENSTEIN alpha GmbH
If you have problems with establishing the connection or in case you need more information on the usage of cynapse® and the Smart Services feel free to contact me directly or our cybertronic support: cybertronic-support@wittenstein.de
