EtherCat error when conneting to Indradrive (MPH08)
TN_X
Hello all,
Im currently connecting ctrlX core to HCS02 and can not switch EtherCat to "OP" state as the picture below.
I'm using ctrlX core - X3 with system image is V2.02.4 together with HCS02, firmware version: MPH-08V22-D5-FD. Code failure: 0x0001: Unspecified error. Please give me advise if you have been through this issue. Also please check in attachment for EtherCat configuration too.
Thanks in advance!
Moved to corresponding sub forum IndraWorks, IndraControl for MLC/MTX, IndraDrive.
Could you please add a parameter file of the drive with all parameter? I guess there is a configuration error in the drive. Please check the logbook of the ctrlX CORE also.
TN_X
Hello CodeShepherd,
Sorry for my late reply.
Your are right. I loaded parameter on previous with sercos configuration and change protocol to EtherCat. Maybe this cause to error. After reseting them I coud connect. Thanks for your hints.
