OPC UA Client app - lost connection
redford
I was able to connect the ctrlX OPC UA client to different OPC servers a few times now (with None Security, that would be enough for us for now and do more later). However, after a short time the ctrlX simply loses the data in the DataLayer or creates new clients that should not be there (default clients [client1, client2,... depending on the number of connections]). In this course the ctlrX also loses the connection. Randomly it also loses the connection after some time (sometimes this way, sometimes that way).
Do you have a solution or an update here?
6 REPLIES 6
Could you please create a system report of your ctrlX CORE after the error(s) occur so we get more information? Afterwards we can have a look at it.
redford
The system report is attached.
We checked your data and it seems to be a known problem in the 1.8 version of the OPCUa client App. Please use version 1.10 (see collaboration room) of it or also update your whole system to this actual version.
Did you do a firmware update and the problems came afterwards?
Any news on this or can the topic be closed?
redford
This topic can be closed. The problem has been solved. It works with the client app version 1.10 . Thanks!
