11-30-2022 03:07 PM
Which formats of certificate types and private keys are accepted by OPC UA and which are not? For example PEM, DER, CER, etc.
12-01-2022 10:43 AM - last edited on 12-01-2022 10:58 AM by CodeShepherd
Hi Maximilian,
The OPC UA Server uses DER encoded certificates and CRLs as required by the OPC UA protocol. Only the private keys are stored as PEM encoded RSA private keys.
For manually uploading certificates we have some restrictions with the naming of the certificate which are explained here:
https://docs.automation.boschrexroth.com/doc/3485899442/certificate-management/latest/en/
Regards Matthias
12-01-2022 10:47 AM
Thank you Matthias.
The link is not working. Is it for Bosch internal only?
12-01-2022 10:58 AM - edited 12-01-2022 10:59 AM
Updated link. See post above.
