10-07-2024 04:28 PM
Hi everyone
I want to communicate with a Rexroth Profinet drive and communicate a plc with Ethernet IP protocol, using the module (COREX-M-X3).
If you can help me I would appreciate it
10-08-2024 08:53 AM
The X3M version with additional right-side added Ethernet port can support the wanted fieldbus-device by loading the propriete app on the ctrlX.
PN_Device App is available at the store.
Examples to setup the PNDevice.PNDevice HowTo_1 , PNDevice_HowTo_2 .
The App for EtherNet/IP is under delevopment and will be released soon.
Aboves info describe the principle to operating the fieldbus-functionality by loading an additional app that realizes the feature on the right-side connected module with XF23/24.
We can support fieldbus functionality integrated by Codesys packages into the PLC-Application.
Further info regarding the usage are listed here .
Does the answer cover your question?
Bye
10-08-2024 05:19 PM
Hi
PN_Device App is not available in the store for download.
I have read the information shared, but I can't figure out how to develop the application I need.
From what I understand profinet communication must be configured, but the side I want to communicate with ethernet/ip how do I develop it?
10-09-2024 09:00 AM
As I understand you want the core to be an EtherNet/IP™ Device under an external PLC and an ProfiNet Scanner for talking to drives under the core?
In that case its enough with a X3 (not modular) and the CodeSys communication packages:
