09-21-2024 10:50 AM
I am using softmotion solution to control my axis for jogging & positioning. while doing so, i had to read the actual velocity feedback of the axis running, which was always in-correct values.
How can i make these feedback values in-line with actual velocity feedback?
09-26-2024 08:12 AM
you must look in the dirve structure.
All target and actual values of the axis are available here
09-27-2024 04:33 AM
Below is picture taken during a trails. while my set value is 10 the actual feedback is only 0.6. is possible to fix this gap?
10-18-2024 09:11 AM
Hello
I think that is a inkonsitece of your scalling or the Units.
Remeber that the softmotion works with units/sec and units is the IPO
10-22-2024 04:20 PM
Can you guide me, . How can i set the proper scaling for the softmotion based applications.
10-23-2024 01:41 PM
Hello you must go in the PLC menu of the drives.
the value of the scaling is dependent on the settings of the axis these are the standard settings for a linear indradrive axis
