02-06-2023 03:27 PM
hello,
today we have bought a library called IIoT Libraries SL | CODESYS Store International to work directly with MQTT.
unfortunately we cannot implement the license in the PLC program.
as soon as we want to use building blocks from the library, we will ask for a password.
there is a possibility?
02-07-2023 11:44 AM
due to the possible support issues by our side, the CoDeSys licensing is not supported by our ctrlX CORE. You can buy the MQTT license at our ctrlX Store (CODESYS - IIoT Libraries (boschrexroth.com)). Please check if CoDeSys takes back the license, you've bought.
kind regards
