Ethernet/IP adapter or Scanner example
Tamer
We have a customer that would like to use the EthernetIP adapter/scanner PLC addon on ctrlX Core, is there a project example available for this topic? Or detailed documentation on how to set it up?
7 REPLIES 7
dhg
Attached a short presentation of Codesys Ethernet/IP scanner.
I hope it is helpful.
Tamer
I have watched the Ethernet/IP example, but it was not very helpful unfortunately as it does not show how to set the Adapter up, rather just a demo that the presenter got it working.
dhg
Maybe you are looking for the installation guide. I attach it.
Tamer
I went through the manual, but it does not show an example of how to set some data points for exchange, it is also outdated as v 1.20 does not have a Package Manager anymore, but Add-on installer instead, which has a bit different user interface.
Thank you so much for sending the presentation, it was well documented and I got it working as an EIP Scanner, please let me know if you come across something simimlar for the EIP Adapter.
georkueh
I added the installation guide using the Add-on Installer.
