Ethernet/IP Scanner eth1 IP address lost
ChrisLarkin
The user of a ctrlX CORE setup with Ethernet/IP scanner has reported a situation of lost IP address.
The IO device connected via eth1 (using Ethernet/IP) reported no communications, Ethernet and EthernetIP scanner devices show "Not Running".
The user traced the issue to eth1 had lost the IP address settings configured during commissioning. No obvious diagnostics to highlight the issue other than "Not Running" message.
Is this a known issue?
For reference this is the same machine from the follow issue. Link
georkueh
which version of ctrlX CORE and Ethernet IP Add-On the customer is using?
kind regards
ctrlX CORE Versoin 1.12 (we plan on upgrading to 1.20 as soon as it's LTS).
Ethernet/IP package 4.2.0.0
georkueh
customer should test with the current CODESYS release 4.4.1.0.
kind regards
georkueh
any news from the customer?
kind regards
