ctrlX core virtual stuck on booting
Servodude
Hello all
I am trying to start the virtual core but it is stock on booting in ctrlX works.
I can see from the terminal window, that the virtual machine is finished booting.
Trying to access the core directly from the browser gives an unknown error.
It has previosly worked on my PC but now I am thinking if my PC is overloaded, since the fan is running all the time.
The model, CPU and installed RAM is
LEN_ThinkPad_T460
Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz 2.50 GHz
8,00 GB RAM
Closing all programs except ctrlx Works and firefox doesnt help.
Any good ideas ?
Re: ctrlX core virtual stuck on booting
The unknown error indicates that there is still some data in your browser cache but no connection to the ctrlX COREvirtual.
Do you have any VPN client or similar active? Because this would prevent your browser and ctrlX WORKS of getting access to control. You could try to run it in port forwarding mode then.
Servodude
Thank you for providing the solution, it works now using the port forwarding allthough it is still running very slow.
