05-25-2022 07:48 AM
Good morning,
after restart my host , and try to run die virtual xctrl , i got an error (Failed to bind socket)
How can i fix this?
Thank you
05-25-2022 12:09 PM
you can go to "Settings"->"Device" and select to show the emulation process window for a running ctrlX COREvirtual.
Then try to start your ctrlX COREvirtual again and look for the upcomming window. This may give you some further information on what went wrong.
05-25-2022 12:31 PM
See also this post.
05-25-2022 01:16 PM - edited 05-25-2022 01:34 PM
Unfortunately , the QEMU windows does not appear. (it's going too fast).. So the frist solution doesnt work..
I checkt all ports with netstat , an all ports are not in use. So the second solution doesnt work too.
Further suggestens ?;)
EDIT: i guess its a problem of the "quem-system-x86_64.exe" befor ists start up with the cli window..
05-25-2022 02:03 PM
sorry for inconveniences.. i just restart my host and it works... problem with the qemu service.
