02-13-2023 06:20 PM
Hi community,
when I try to start the Core Virtual, a message appears "C:\Program Files\Rexroth\ctrlX WORKS\qemu\qemu-system-x86_64.exe: - append: requires an argument"
Am I missing configuration?
Thanks!
02-14-2023 08:00 AM
There is no setting to be done for this as it is coming with the standard installation.
02-14-2023 03:48 PM
- Version is 1.12.10
-It is installed directly on my PC
here the content of the file xxxx.start.bat
"C:\Program Files\Rexroth\ctrlX WORKS\qemu\qemu-system-x86_64.exe" -L "C:\Program Files\Rexroth\ctrlX WORKS\qemu" -machine q35,accel=hax:tcg -smp 4 -m 1G -netdev tap,id=eth0,ifname=VirtualControl-DE-AD-BE-00-00-01 -smbios "type=1,manufacturer=Bosch Rexroth AG,product=ctrlX COREvirtual,version=1.12.21,serial=4C4C4544-005A-4210-8053-C7C04F395333,uuid=4C4C4544-005A-4210-8053-C7C04F395333" -device virtio-net-pci,netdev=eth0,mac=DE-AD-BE-00-00-01 -drive "file=C:\ProgramData\Rexroth\ctrlX WORKS\virtual-controls\images\1.12.21\nz1w1qk0.user.qcow2,media=disk" -kernel "C:\ProgramData\Rexroth\ctrlX WORKS\virtual-controls\images\1.12.21\kernel.img" -initrd "C:\ProgramData\Rexroth\ctrlX WORKS\virtual-controls\images\1.12.21\initrd.img" -net user,restrict=off -monitor tcp:127.0.0.1:65000,server,nowait -append " hostname=VirtualControl-1 usage=evaluation" -display sdl
02-15-2023 08:17 AM
Hello JoaqoGarcia,
when you add a new virt. control in WRK-V-0112.10 and start the control, a batch file like this is created:
"C:\Program Files\Rexroth\ctrlX WORKS WRK-0112\qemu\qemu-system-x86_64.exe" -L "C:\Program Files\Rexroth\ctrlX WORKS WRK-0112\qemu" -machine q35,accel=hax:tcg -smp 4 -m 1G -netdev tap,id=eth0,ifname=VirtualControl-DE-AD-BE-00-00-03 -smbios "type=1,manufacturer=Bosch Rexroth AG,product=ctrlX COREvirtual,version=1.12.21,serial=BB41E3C8-A4B3-11E8-9C43-BC0000CC0000,uuid=BB41E3C8-A4B3-11E8-9C43-BC0000CC0000" -device virtio-net-pci,netdev=eth0,mac=DE-AD-BE-00-00-03 -drive "file=C:\ProgramData\Rexroth\ctrlX WORKS\virtual-controls\images\1.12.21\l04glwpd.user.qcow2,media=disk" -kernel "C:\ProgramData\Rexroth\ctrlX WORKS\virtual-controls\images\1.12.21\kernel.img" -initrd "C:\ProgramData\Rexroth\ctrlX WORKS\virtual-controls\images\1.12.21\initrd.img" -net user,restrict=off -monitor tcp:127.0.0.1:65000,server,nowait -append "earlycon clk_ignore_unused rng_core.default_quality=700 panic=-1 systemd.gpt_auto=0 rd.systemd.unit=basic.target snapd_recovery_mode=run console=ttyS0 console=tty1 net.ifnames=0 hostname=VirtualControl-3 usage=evaluation" -nographic
As you might see, it differs from your file. Did you change it manually? If yes, you need to pass the arguments right. I think the problem is the blank before hostname in your file. I would propose to start the control in the ctrlX WORKS Application. Then it should work.
Regards,
Oliver
02-15-2023 04:16 PM
I didn't change that file. I changed the file for a test , but it is regenerated when I start the CoreVirtual.
03-03-2023 10:14 AM
But the display sdl argument is not generated in our current software, we generate no graphics. Are you shurly using an up to date installation and starting the right exe?
04-24-2023 09:02 AM
