10-12-2021 10:36 AM
Hello.
I'm trying to use the IDE app version 1.10.12 and it works well if I use the Visual Coding section, but I could not start the Textual Coding section. After I click on that the page opens but freeze and nothig happens.
Could you help me ??
Many Thanks
Giuseppe
10-12-2021 12:17 PM
There seems to be a Problem with the IPv6 communication. We will check this.
Please use the IPv4 in the meanwhile.
10-12-2021 01:27 PM
sorry but could you give me some advice about how and where should I change the communication settings usin IPv4 ?
Many Thanks
Giuseppe
10-12-2021 01:39 PM
sorry I got it. Enternin the Visrual control using the IPv4 adress the Textual coding works
Regards,
Giuseppe
10-13-2021 12:28 PM
