How is it possible to connect to a ctrlX CORE not shown in ctrlX WORKS or network folder without knowing its IP?
Assuming: - the ctrlX is not visible in ctrlX-Works or the Explorer/network and the IPsetup is unknown
- default setting of "enable DHCP" was not modified by the user in meantime
a reset can be avoided if a DHCP server assigns a IP adress to the ctrlX. Instead of placing a router HW to provide the IP-assigning there are several 'DHCP server for PCs available.
Exemplarily the following convinced by easy setup and handling.
https://www.dhcpserver.de/cms/running_the_server/
Installation and setup described in detail.
Once the dynanic adress was given by the DHCP Server, connecting the landing-page is possible and the static-IP adress can be adjusted once again.
