right now, i am right at the beginning to learn something about the CtrlX Core. But unfortunately, i failed already when booting a virtual Core. The message was "An active VPN connection was detected. The network mode 'Network Adapter' will not work. Change the network mode to 'Port Forwarding'.".
When I try to boot with 'Port Forwarding', the following error message occurs: "C:\Program Files\Rexroth\ctrlX Works\qemu\qemu-system-x86_64.exe: Could not set up host forwarding rule 'tcp::4840-:4840'".
When I add a firewall income and outcome rules, nothing changes. The system will not boot at all.
Regards,
Fabian
