02-21-2024 11:55 AM
As i wrote in the title i'm getting an error when trying to install sqlite from manage palette, i managed to install several others components but this isn't working. this is the log ( i also tried to install directly the tgz file but it is still not working). Thanks you
02-21-2024 01:04 PM
Did you already check e.g. this post that shows steps to go to install a palette?
02-21-2024 03:18 PM
Hello @AlbertoGiani ,
Are you doing this on a physical or virtual CORE? What versions of ctrlX OS apps and Node-RED are installed?
I just installed this pallet on a physical CORE with 1.20 apps and did not experience this issue.
03-06-2024 11:58 AM
Hello, i'm doing this on a virtual core, i have ctrlx version 1.20.9 and node red: 1.20.0 + 3.0.2-ctrlx
03-06-2024 04:03 PM - last edited on 03-06-2024 04:11 PM by CodeShepherd
Please do not make duplicate posts (see Nodered 1.20.0 + 3.0.2-ctrlx, can't install sqlite). I was able to reproduce this with your versions. This is a problem specific to the virtual CORE architecture. In the pallet documentation, native code is compiled on the device during installation and this is where the failure occurs. The npm package sqlite3 is used which looks to only be supported on arm architecture.
Unfortunately, prebuild cannot differentiate between armv6
and armv7
, and instead uses arm
as the {arch}
. Until that is fixed, you will still need to install sqlite3
from source.
As this is a 3rd party node, this is about as much support as I can provide here. It should work fine on an arm device.
03-21-2024 11:54 AM
Hello and thanks you for your reply, unfortunatly i need to install sqlite on my virtual core because i have really limited access to the physical core and I will be able to use it ony for a couple hours when i have finished to prepare the whole project in virtual. Do you have any idea of any solution? how can i install sqlite from source as you suggested? thanks you
03-28-2024 06:00 PM
03-28-2024 06:43 PM
It worked! you saved me ahhaa thanks you very much for all the help
03-29-2024 03:13 PM
Sorry, but I don't think this works actually. I could install, but the nodes do not function. I believe it is because the package calls for a native compilation...
