IDE App: No License available
AkashDve
I am not able to run/compile any project in the Visual coding inside IDE App due to an error message of "No License avaiable". Also Textual coding is not booting up.
Things I have tried to resolve the issue but nothing worked so far:
  1. Reinstalled IDE App v1.18.37
  2. Reboot / Shutdown
  3. Soft Reset from Visual Coding
  4. Factory Reset from system setting of the ctrlX Core
  5. Tried IDE App v1.18.29
  6. Exported license file again
My System Info:
  1. ctrlX Core image: v1.20.5
  2. IDE App: v1.18.37 / v1.18.29
-> License file is accepted by the core
Any ideas how to fix this? Thanks for help.
MauroRiboniMX
Contributor
i try to find if someone had a similar problem and then i come back to you.
Is your system time set correctly? Did you try do empty your browser cache or use a private tab in your browser?
Is there a ctrlX Python Runtime installed on your system, if no, programs will not be able to run. Also it can cause issues in the IDE app.
Also a missing ctrlX MOTION can cause problems in this versions of the IDE app.
Nice hint,
I have not noticed the advice icon with a warning. That can be also the bad time setting!
Thanks a lot for pointing out the date/time issue. I did reset the time on the Core and it works now.
