09-25-2024 08:36 PM
Using a large project that contains 8 safeX communicating over SMMC, when a project is copy and pasted in safety engineering 1.8.3 the software crashes. I'm able to copy over a blank project, but with the full project (20+ I/O per project, ethercat data transfer, fastChannel) Safety Engineering crashes. The exception report generated is attached.
After the software crashed, I was able to open a recovery file. I found a section that was deleted during the copy and paste, so I thought that might be the issue. I removed those items and tried a new copy and paste. This second copy and paste also failed, but with very different issues in the recovery file. My theory is there's a memory issue and when that memory runs out, the next item being pasted is what gets messed up crashing the software. By deleting the initial items, I moved the problem to the next thing being pasted.
09-26-2024 10:05 AM - edited 09-26-2024 10:10 AM
@jbiewendnjmcdirect wrote:Using a large project that contains 8 safeX communicating over SMMC, when a project is copy and pasted in safety engineering 1.8.3 the software crashes. I'm able to copy over a blank project, but with the full project (20+ I/O per project, ethercat data transfer, fastChannel) Safety Engineering crashes. The exception report generated is attached.
I think you're experiencing a complex issue with the Safety Engineering software. Have you considered checking the software's memory usage during the copy and paste process? It could help confirm if memory constraints are contributing to the crashes.
10-03-2024 06:16 PM
I just performed the same copy and paste while monitoring the memory usage. The copy paste didn't affect the memory usage any significant amount. 😕
a month ago
Could please send me some information, so we can try to reproduce the issue:
Also send me via a private message
a month ago - last edited a month ago
@jbiewendatfbooru wrote:Using a large project that contains 8 safeX communicating over SMMC, when a project is copy and pasted in safety engineering 1.8.3 the software crashes. I'm able to copy over a blank project, but with the full project (20+ I/O per project, ethercat data transfer, fastChannel) Safety Engineering crashes. The exception report generated is attached.
Consider checking the software's memory usage during the copy and paste process. This could help confirm if memory constraints are causing the crashes.
4 weeks ago
Safety Engineering was version 1.8.3. Firmware was 1.0.1.47, but the software would crash before I could load the project into the safety controller. So I don't think the firmware would be a factor?
I'll send a private message with contact info and the project file.
