05-23-2024 08:34 AM
Are there any further details on the SAFEX two handed control function block?
eg. Logic diagram, timing diagram, discrimination time between the two inputs, faults detected?
I am reluctant to use it with so little information provided. However, I also would prefer to use a pre-tested function block rather than write my own software.
a week ago
Hello Bruce,
there are no more details for Two-Hand Control. It is also not possible to deactivate the Cross Circuit you can do this but the wiring is always the same:
I made a test with this Configuration but nothing happen no function.
For the moment it is the best make your own User Group.
