06-30-2022 08:48 AM
Dear community,
will the zenon PLC-Handler (3S_V3 driver) be supported by ctrlX PLC?
07-01-2022 11:22 AM
Hello Tobias,
as far as I see in the documentation of the zenon PLC Handler the interaction with the Codesys PLCHandler is integrated.
Since the ctrlX PLCRuntime V3 is integrated I would expect that it will work.
Bye Jens
07-07-2022 03:18 AM
Have you true PLC Handler, does it work?
07-14-2022 11:10 AM
other customer operate with their intergrated PLCHandlers on HMI/PC side already. Our codesys version supports the PLCHandler.
Encrypted communication had been in issue in former versions but as long that is supported the com works.
So its a question to place at zenon/copadata to verify. Screen above was available in their docu.
OK?
Bye
07-20-2022 04:53 AM
Thank you for your information.
