10-12-2023 10:58 PM
When a PLC open program contains "MC_MoveAbsolute" or "MC_MoveRelative", the PLC program compiles without a fault. But when the program is downloaded to ctrlX CORE following error message is generated. [FATAL ERROR] Unresolved reference: 'ML_AXSPOSABSEX'. I cannot find any description of "ML_AXSPOSABSEX". What is the reason for the error?
ctrlX CORE works without a problem when "MC_MoveVelocity" function block is used and the system runs in velocity mode.
10-13-2023 07:00 AM
Please check your version of
This version must be fit together, means come from the same RM.
Background:
With newer versions the PosDirection was add to the FB. And it seems that your PLC-Engeneering (library) is newer than the motion app running at the ctrlX CORE.
Jochen
10-16-2023 04:08 PM
10-17-2023 07:14 AM - edited 10-17-2023 07:14 AM
At least the major versions of the ctrX PLC app and the ctrlX PLC Engineering needs to fit. For your case it would be app version 1.20.4 in combination with engineering 1.20.1 (part of ctrlX WORKS 1.20.5) OR app version 2.02.0 in combination with engineering 2.2 (part of ctrlX WORKS 2.02.2). The libraries are included accordingly.
Please keep in mind that also the major version of the base system needs to fit.
