ctrlX PLC Engineering: Upgrade Storage format for this project
MrLurtle
I usually get following message if I download my PLC in the ctrlX:
If I hit "OK" button, the project will be updated in some way and is not be able to open in PLC Engineering anymore.
If I hit "Cancel" everything works well. I can download, switch online and so on, until I want to download again.
I am using ctrlX PLC Engineering 1.14.1. Why should I update my Project to a version, which I can not use with my actual version anymore?
What can I do to remove this window? I actually tried to deinstall and install PLC Engineering without any changes in this behaviour.
It seems that you are using an old project e.g. in version 1.12 of ther CTRLX PLC Engineering. Could you please confirm, that you are also using the PLC app in a version 1.12? The project version has to fit to the app version at the moment. So your engineering seems to be too new for the app and project version.
