06-10-2022 10:07 AM
I usually get following message if I download my PLC in the ctrlX:
If I hit "OK" button, the project will be updated in some way and is not be able to open in PLC Engineering anymore.
If I hit "Cancel" everything works well. I can download, switch online and so on, until I want to download again.
I am using ctrlX PLC Engineering 1.14.1. Why should I update my Project to a version, which I can not use with my actual version anymore?
What can I do to remove this window? I actually tried to deinstall and install PLC Engineering without any changes in this behaviour.
06-14-2022 09:52 AM
It seems that you are using an old project e.g. in version 1.12 of ther CTRLX PLC Engineering. Could you please confirm, that you are also using the PLC app in a version 1.12? The project version has to fit to the app version at the moment. So your engineering seems to be too new for the app and project version.
11-22-2022 11:27 AM
