Switching the ethercatmaster state does not work
Open
I am new to CXA_EtherCATMaster library and i have the similiar issue, the CytroPac when it power on it is in Safe-OP mode and need to switch to INIT -> OP mode for it to be operational.
I tried following your code:
Declaration:
PROGRAM PLC_PRG
VAR
	//CytroPac EtherCAT Switch State OP -> INIT -> OP
	fbECATMasterGetBusState: 				IL_ECATMasterGetBusState;
	eActBusState: 							IL_ECAT_STATE;
	fbECATMasterSetBusState:				IL_ECATMasterSetBusState;
	fbIL_ECATRemoteSlaveGetDevState1:		IL_ECATRemoteSlaveGetDevState;
	eActDevState1:							IL_ECAT_STATE;
	fbIL_ECATRemoteSlaveGetDevState2:		IL_ECATRemoteSlaveGetDevState;
	eActDevState2:							IL_ECAT_STATE;
	fbIL_ECATRemoteSlaveGetDevState3:		IL_ECATRemoteSlaveGetDevState;
	eActDevState3:							IL_ECAT_STATE;
	fbIL_ECATRemoteSlaveSetDevState1:		IL_ECATRemoteSlaveSetDevState;
	fbIL_ECATRemoteSlaveSetDevState2:		IL_ECATRemoteSlaveSetDevState;
	fbIL_ECATRemoteSlaveSetDevState3:		IL_ECATRemoteSlaveSetDevState;
	strMasterName:							STRING := 'ethercatmaster';
	iSetMaster: INT;
	bExecute: BOOL;
END_VAR
Implementation:
fbECATMasterSetBusState.Execute := bExecute;
fbECATMasterSetBusState.MasterName := ADR(strMasterName);
CASE iSetMaster OF
	0: //Automatically Start every slave in OP mode
		IF NOT (eActDevState1 = ECAT_STATE_OP AND eActDevState2 = ECAT_STATE_OP) AND eActDevState3 = ECAT_STATE_OP THEN
			fbECATMasterSetBusState.NewBusState := IL_ECAT_STATE.ECAT_STATE_INIT;
		ELSIF eActBusState = ECAT_STATE_INIT THEN
			fbECATMasterSetBusState.NewBusState := IL_ECAT_STATE.ECAT_STATE_OP;
		END_IF
	1:
	2:
		fbECATMasterSetBusState.NewBusState := IL_ECAT_STATE.ECAT_STATE_PREOP;
	3:
		fbECATMasterSetBusState.NewBusState := IL_ECAT_STATE.ECAT_STATE_SAFEOP;
	4:
END_CASE
fbECATMasterSetBusState();
IF fbECATMasterSetBusState.Done THEN
	; // Master reached operational state
END_IF
IF TRUE = fbECATMasterSetBusState.Error THEN
	; // Error handling
END_IF
When i write iSetMaster = 1 (Switch EtherCAT Master State INIT), my ctrlX EtherCAT Master state remain OP.
does anyone have a code example for switching between EtherCAT state? i have seen this example but i do not understand how the switching works.
Warmest regards,
Moved to own topic from "Switching the ethercatmaster between states".
Did you check the sample in the library CXA_EtherCatMaster itself? As your code looks quite similar I guess yes. Could you try switching to one state at a time?
Do you also write "bExecute := true" after choosing "iSetMaster := 1", so that function block execution gets started?
Open
Hi CodeShepherd,
i got it working now for the function block to work i need to give execute variable false then true.
Open
Hello @CodeShepherd ,
I am facing issue with reading the EtherCAT State in PLC.
I followed the code above. The value i received is ECAT_STATE_UNKNOWN.
Anyone also had the same issue?
Warmest regards,
Open
I have solved it.
I used fbIL_ECATRemoteSlaveGetDevState1.ActDevState = ECAT_STATE_OP instead of eActBusState1.
Declaration:
PROGRAM EtherCAT_Auto_Switching_OP_INIT
VAR
  strMasterName                   : STRING := 'ethercatmaster';
  eActBusState1                   : IL_ECAT_STATE;
  eActDevState1: CXA_EthercatMaster.IL_ECAT_STATE;
  eActBusState2                   : IL_ECAT_STATE;
  eActDevState2: CXA_EthercatMaster.IL_ECAT_STATE;
  eActBusState3                   : IL_ECAT_STATE;
  eActDevState3: CXA_EthercatMaster.IL_ECAT_STATE;
  fbIL_ECATRemoteSlaveGetDevState4: IL_ECATRemoteSlaveGetDevState;
  eActBusState4                   : IL_ECAT_STATE;
  eActDevState4: CXA_EthercatMaster.IL_ECAT_STATE;
	fbBLINK: BLINK;
	bBlinkOut: BOOL;
	//AUTO Switching Condition
	fbIL_ECATRemoteSlaveSetDevState4:		IL_ECATRemoteSlaveSetDevState;
	iSetMaster: INT;
	bExecute: BOOL;
END_VAR
Implementation:
//Read EtherCAT State
//1001
fbBLINK(ENABLE:= TRUE, TIMELOW:= T#1S, TIMEHIGH:= T#1S, OUT=> bBlinkOut);
fbIL_ECATRemoteSlaveGetDevState1.Execute      := bBlinkOut;
fbIL_ECATRemoteSlaveGetDevState1.MasterName   := ADR(strMasterName);
fbIL_ECATRemoteSlaveGetDevState1.SlaveAddress := 1001;
fbIL_ECATRemoteSlaveGetDevState1();
IF TRUE = fbIL_ECATRemoteSlaveGetDevState1.Done THEN
  eActDevState1 := fbIL_ECATRemoteSlaveGetDevState1.ActDevState;
END_IF
IF TRUE = fbIL_ECATRemoteSlaveGetDevState1.Error THEN
  ; // error handling
END_IF
//1002
fbIL_ECATRemoteSlaveGetDevState2.Execute      := bBlinkOut;
fbIL_ECATRemoteSlaveGetDevState2.MasterName   := ADR(strMasterName);
fbIL_ECATRemoteSlaveGetDevState2.SlaveAddress := 1002;
fbIL_ECATRemoteSlaveGetDevState2();
IF TRUE = fbIL_ECATRemoteSlaveGetDevState2.Done THEN
  eActDevState2 := fbIL_ECATRemoteSlaveGetDevState2.ActDevState;
END_IF
IF TRUE = fbIL_ECATRemoteSlaveGetDevState2.Error THEN
  ; // error handling
END_IF
//1003
fbIL_ECATRemoteSlaveGetDevState3.Execute      := bBlinkOut;
fbIL_ECATRemoteSlaveGetDevState3.MasterName   := ADR(strMasterName);
fbIL_ECATRemoteSlaveGetDevState3.SlaveAddress := 1003;
fbIL_ECATRemoteSlaveGetDevState3();
IF TRUE = fbIL_ECATRemoteSlaveGetDevState3.Done THEN
  eActDevState3 := fbIL_ECATRemoteSlaveGetDevState3.ActDevState;
END_IF
IF TRUE = fbIL_ECATRemoteSlaveGetDevState3.Error THEN
  ; // error handling
END_IF
//1004
fbIL_ECATRemoteSlaveGetDevState4.Execute      := bBlinkOut;
fbIL_ECATRemoteSlaveGetDevState4.MasterName   := ADR(strMasterName);
fbIL_ECATRemoteSlaveGetDevState4.SlaveAddress := 1004;
fbIL_ECATRemoteSlaveGetDevState4();
IF TRUE = fbIL_ECATRemoteSlaveGetDevState4.Done THEN
  eActDevState4 := fbIL_ECATRemoteSlaveGetDevState4.ActDevState;
END_IF
IF TRUE = fbIL_ECATRemoteSlaveGetDevState4.Error THEN
  ; // error handling
END_IF
fbECATMasterGetBusState.Execute    := bBlinkOut;
fbECATMasterGetBusState.MasterName := ADR(strMasterName);
fbECATMasterGetBusState();
CASE iSetMaster OF
		IF NOT (fbIL_ECATRemoteSlaveGetDevState1.ActDevState = ECAT_STATE_OP) AND (fbIL_ECATRemoteSlaveGetDevState2.ActDevState = ECAT_STATE_OP) AND (fbIL_ECATRemoteSlaveGetDevState3.ActDevState = ECAT_STATE_OP) AND (fbIL_ECATRemoteSlaveGetDevState4.ActDevState = ECAT_STATE_OP) THEN
		ELSIF fbECATMasterGetBusState.ActBusState = ECAT_STATE_INIT THEN
		END_IF
	1:
	2:
	3:
	4:
END_CASE
END_IF
	; // Error handling
END_IF
