PLC API: importing PLCopenXML files (nodeurl?)
Polygon
I have succesfully imported the openXML files with the help of API-reference & How to article.
API-client is requiring "nodeurl" to point out the destination of imported entities. In the API-reference's example the nodeurl was following:
/devices/device/PLC Logic/Application
What is the nodeurl for importing entities to POUs-tab instead of Devices-tab?
Tags (2)
Re: PLC API: importing PLCopenXML files (nodeurl?)
Did you check the POUs area of the API description?
ctrlX PLC Engeneering Swagger APIctrlX PLC Engeneering Swagger API
Polygon
Yes I have read the description for POUs also, but I dont think it will solve my problem. Or am I missing something?
Can you explain what this "nodeurl" is?
I did some test and found that it is at the moment not possible to import xml files to to the root of the POUs via the REST API of the ctrlX PLC Engineering. You will have to add a parent folder and import into this one:
import in POUsimport in POUs
